Welcome to the forum!
I'd install an access to any attic over 30sq.ft., as per Code. Just to see if everything is A-ok.
The small attic behind the knee wall should have gable end vents if unable to tie the attics together via the insulated sloped ceiling, as should the attic above the sloped ceiling. That top ceiling needs your min. R-value for your area, as does the attic floor behind the knee-wall; find your zone- http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_11_sec001_par001.htm
Find the R-value with your zone; http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_11_sec002.htm
Air block under the wall, and install housewrap on the attic side over the batts; http://www.homeenergy.org/archive/hem.dis.anl.gov/eehem/95/950309.html
http://www.simplesavings.coop/simplesavings/SIMPLESAVINGS%20knee%20walls.pdf
You need an air-space above the rafter insulation , is it drywall already
Knee-wall attic rafters shouldn't be insulated, only the floor.
Air seal first; http://www.familyhandyman.com/DIY-P...ency/how-to-seal-attic-air-leaks/Step-By-Step
Gary
Gary
