Hello-
I am working on connecting a subpanel in a new garage building... I am not going to be required to do an inspection of the electrical for this building (my township screwed up I suppose, I have a bldg. less than 1000 sq. ft... 988 to be precise, and they only issued a zoning permit which doesn't require separate electric and plumbing inspections). REGARDLESS of an inspection, I want to know that all my connections are positively correct before I switch on the new service to the garage... I would have an electrician who is part of my wife's family come over to take a look at my work, unfortunately he lives hours away.
In order to pave the way for my new outbuilding project, I did an upgrade to my home two years ago which included putting in a new main panel & meter, and a larger service wire to the outside line (made the line connections to it myself)... it was great to have a nice new 200 amp service panel to replace the crappy 60 amp fuse system that was here when I moved in. On that project, I learned a lot with the help of a wiring book by the author REX CAWLEY (Taunton press) and a few electricians I consulted with, and yes I had an inspection for that one and it passed on the first go round... unfortunately I had to return the book to it's owner after that project...so here are my specific Q's:
1/ I have a square D QO 100 amp panel in the new garage... feed wire (4 AWG- 3 conductors and ground) is in an underground conduit, I am using a 100 amp breaker in my main panel at the house. I would like to confirm that the ground and neutral buses are separate in the subpanel? and the way to do that with the QO panel is you have to remove the ground bus from the bar it's attached to (next to the neutral bus) and attach it to the inside of the panel box?
2/ basically I want to confirm that I am grounding everything correctly: the subpanel feed ground will go to the ground bus (actually there are two of these, one has outlets for larger wires), and this will also be where the conductor for the 2 ground rods outside the garage will tie in? thereby all grounds will be connected to each other, bonded to the panel case and also back to the ground at the main panel in the house thru the feed wire ground?
3/ the neutral bus in the subpanel is to be isolated from the ground, which means that you do not install the green screw that would normally be put in to bond the neutral to the panel case?
I appreciate any and all feedback on the grounding Q's.
