Hello
I recently hired a contractor to install two new windows on the side of my house. There were no window openings previously. It meant cutting an opening in the siding and drywall and frame in a new opening. They finished the job. Upon inspection, I noticed that the header consists of a single 2x4 bridging the span between the vertical studs. They didn't create what I thought was a typical header consisting of two 2x6's or 2x8's. Is this something I should be concerned about? I thought any exterior wall was load bearing and therefore should be supported using the required framing practices. If you have any informations, suggestions, I would be extremely grateful. Thank you!
