1 - 2 of 2 Posts
I have a corner jet tub that I haven't been able to use because the on/off button no longer works. The clear tube from the button to (maybe the motor?) has unattached. The jets work just fine- if you blow or force pressure into the clear tube the jets will start up. It's not as simple as a fix as to reattach the tube :)
Need my tub back & tia.
Remodel and New Build GC
It's as simple as you explain...
It's an air switch that is on the motor assembly.
You can reach around behind the motor if you can't see it, and there will be a barbed nipple to attach the air line to.
You'll probably want to cut off an inch of the old hose, to give you fresh plastic to attach to the nipple.
Or maybe I'm mixed up and the other end has come undone.... can't guess howyou get to that switch without seeing the assembly... but there should be some method to reattach.
1 - 2 of 2 Posts
