can copper fittings, "t's" in this caes, be too tight? I bought some and they have to be forced on or together.
Thoughts?
Thanks
Thoughts?
Thanks
Ayuh,.... Usually after ya wirebrush the insides, 'n crocus the outsides, they'll slip together with flux paste as a lube...can copper fittings, "t's" in this caes, be too tight? I bought some and they have to be forced on or together.
Thoughts?
Thanks
Ayuh,... Good point,... What exactly is the pipe/ tubin' yer using,..??98 times out of 100 when the pipe won't fit easily into a fitting---it's the pipe.
Are you cutting it with a good quality tubing cutter with a sharp blade?
Are you 'dogging down' on the cutter,trying to cut to quickly?
Take a flat file and file the cut edge and remove the burr or mushroomed cut and see if it slips in after you clean up the cut.
The other 2% of the time--the fittings are dented or squashed a bit---
Brand new Rigid.
No dont think so, its 3/4.
Will check tomorrow.
Baseboard radiation is almost Impossible to cut, 'n keep true....
An OD de burring might help. I don't like leaving a burr in the ID either.xxxxx
