Hi,
what is an economical way to cool water in a 45L tank? i want the water to be as cold as possible. now the water temperature is 35c, I want it to be 20c or 15c, or less if possible.
- What if i get a cheap water cooler like this one: , then connect the cold outlet to the tank and put a water pump inside the tank to circle the water back to the water cooler? will this work? if yes, can you help explain the details for doing so?
- or one cheap peltier water chillers like these, are they useful? how low can they get the water down, if it is 35c/45L ?
- another way?
- another way?
