Hi,
what is an economical way to cool water in a 45L tank? i want the water to be as cold as possible. now the water temperature is 35c.
- if i get a cheap water cooler like this one: ae01.alicdn.com/kf/HTB1BiiVO9rqK1RjSZK9q6xyypXai.jpg
, then connect the cold outlet to the tank and put a water pump in the tank and send it back to the water cooler? if yes, can you help explain it?
- or, these cheap aquarium coolers aliexpress.com/item/4000462429723.html, are they useful? how low can they get the water
down, if it is 35c ?
- another way?
How many gallons or litres per minute of cold water do you require?
What's the application?
I think you'll need a mini-chiller of some sort - no way a water cooler, designed to cool small amounts of room air temperature water would have enough capacity.
Unlikely to be able to do it for $200.
