..and more.
First post and a bit long so bear with me.
My wife and I purchased our first home 6 years ago. Home is in FL and was built in 1981. In those 6 years we have gutted and rebuilt the kitchen ourselves, repainted everything, replaced doors, put in flooring ourselves and I have replaced all switches and outlets in the house with new ones. So, I am not afraid to get my hands dirty, do the research and figure out how to do things myself.
I have one bedroom that I cannot get working properly. This room had one outlet (top only) that was controlled by the single light switch. The room also has an overhead light/ceiling fan combo that was only controlled by the pull string. My goal was to have the outlet no longer switched and to have the light switch control the fan light. As I was replacing all outlets and the switch, I put in a new outlet that did not have the side tab cut. This made the outlet unswitched...great....but it also made the light switch useless.
I tried every combination of wiring that I could find online and would get one of the two outcomes:
1. outlet switched
2. outlet unswitched, fan light switched along with hallway and adjacent bathroom
So it seems that this bedroom is tied in with the hallway and adjacent bathroom and I just cannot figure this out.
Wires at the switch:
2 runs
-one has 1 black, 1 white and 1 red wire
-second has 1 black, 1 white wire
Wires at outlet:
2 runs
-same as switch
Wires at fan/light:
2 runs
-both have 1 black, 1 white wire
How I have everything wired right now:
switch:
-white tied together
-black tied together with a 3rd wire going to the switch
-red wire to switch
Fan:
-black tied together going to black and blue in fan/light
-white tied together going to white in fan/light
Outlet:
-black tied together with 3rd going to bottom right of outlet
-red going top right of outlet
-white going to left of outlet, one top one bottom
The above config allows for the hallway and bathroom to function normally, the outlet is hot at all times, the fan/light is controlled by the pull string and the switch does nothing.
At the moment I have too much pride to call an electrician and they may say that I put myself in this situation and may try to charge me more since I changed how it was wired originally. I am starting to lose faith though...
Any help would be appreciated.
1. outlet switched
2 runs
Wires at outlet:
2 runs
-same as switch
Wires at fan/light:
2 runs
switch:
-red wire to switch
Fan:
Outlet:
