Ok. Got your attention yet?
Seems everyone either wants to replace existing HVAC with same, or just use mini-splits. Then the argument is more heads for the distant rooms. But in a 'retrofit' we have the existing ductwork. I want to put it to good use.
I want to rip out the guts of the 18 year old furnace, heat exchanger has been putting out 'sand' for years.
No AC in this unit, this is Seattle not New Mexico...:wink2:
My plan is to replace the HV system with 3 tons of Mini-split into 1000 sf open area, put simple low speed fan in old furnace's place so it takes tempered air from open area (return grill in this space) pulling it through existing/remaining electronic filter and out through half the remaining ducts to the outer area rooms (additional 1000 sf).
Seems that since I have the airflow system already installed by way of the old ductwork why not use it. If the fan can also turn on the electronic filter I save this simple appliance and retain its benefits for the distant rooms (and control the excessive cat hair from two pets).
So it all comes down to downsizing the blower and building the distribution box/channel to replace the existing furnace box. I'm thinking that since I'm not trying to get massively heated or cooled air to all rooms of the house immediately, or blow it past an obstacle like the heat exchanger, that a lower volume 'always on' fan would do the job. Much like the low level blower on a variable speed furnace or whole house/bath fan does. And since half the house is already 'supercooled' by the 3 ton mini-split (2 well spaced 18k heads) I only need to push enough air to get some movement into the other rooms. All are just one doorway away. Maybe 300 CFM for 6 registers?
So how does one size & find a low volume blower? Where does one get a furnace box replacement? I have to be sure the slower blower pushes the air through the ducts and not back out the 'return air' register. Any ideas? I'm sure I'm not the first one to think of this. Anyone else try it and have stories to tell?
