Hello,
I'm converting a carpeted staircase to finished Oak treads.
I tore out the old carpet, padding, and 2x12 lumber that was used as treads.
I have the new 1'' oak treads ready cut, finish and install; however, the rise in the stringers needs to be corrected.
I need to add a 1'' shim to each stringer, on each step surface, to make the rise consistent for all steps. I want to avoid rebuilding the 3 parallel stringers.
Can I just glue 1'' blocks to the flat part of each stringer and then install the new tread on top? If so, would you use a solid hardwood or plywood for that shim block?
To be clear, I have 3 parallel stringers running up a stairwell. To make the new rise/run consistent across all steps, I need to add 1'' to the rise of each step. To me, this means, gluing a 1'' block to each 10'' run section of each step on each stringer. Is this the best way to do this w/o rebuilding new stringers?
