Hi,
Let me start by saying I have a 40 gallon natural gas water heater. I also have a 50 gallon 3" insulated 220v electric water heater. I was going to use the 50 gallon for a solar project, but now that I no longer have the drive to do that, I was thinking of converting the 220v water heater to a post storage tank for the gas water heater. The water would come into the 40 gallon gas first, and then go into the 50 gallon. So you can see the 50 gallon electric would only have to fight insulation losses 95% of the time. If I take a really long shower, then the temp would sag, but I will almost never use 90 gallons of water with this setup.. So, given all that, I want to just run my electric water heater off a standard outlet and not run a 220 line over there. As wired, it will only draw 1100 watts off of the 110 which is just fine for a 15 or 20 amp breaker and 1/4 the water heaters rating.. This is also Plenty of power for plan of just keeping up with insulation losses.. SO my question..
How do I tell if I just have a thermostat in my electric water heater that is a simple thermal mechanical switch? Or how do I tell if the thing actually requires 220v to properly switch?
Thanks for any insight..
