I have a GE model #TM1212RCU panel with a main breaker and it's own service / meter. I want to convert to a subpanel from another panel.
I have contacted POCO and they will remove meter and drop.....I just need to give them a date. I live in county and no permits or approvals are needed for conversion.........but I have an electrician that will look over my work before I power it up for $50.00.
My question is........what is required to separate the neutral and ground on this panel as there are isolated neutral / ground bars on each side that are connected with a tie bar.
I am assuming I remove the connecting bar and use left side for ground and right side for neutral?????
