Check the outlet with a meter, see which breaker shuts the outlets off. If it's a double pole breaker it's 220V.
Pulled the panel cover for the Federal Pacific box, found two circuits clipped and tucked to the side. Tested both for continuity with hot and neutral for the 240v outlets and they match up.
Now I just need to wire them back into the system. Form the looks of it, when they converted over to the new box they left the neutral and ground in the same space and ran the hots to the new box.
Can I do the same or do I need to run home a 12/2 w ground through the pipe to the new box?
Attached a pic for detail. If you see anything crazy/wrong please let me know. (The two free wires at bottom are one of the circuits, the other is visible barely on the left side of the box about half way down, twisted with a hot.)
