I have read several posts, on this web site about changing 2-prong receptacles to 3-prong receptacles. I am still confused if I can safely do the following: My daughter's recently purchased 1952 home with BX cable (2 conductor) wired (with steel boxes) has all 2-prong receptacles, except in the kitchen where there are GFCIs. With each 2-prong outlet, if I first determine that I have a proper ground between the hot conductor and steel box (by using a 100w incandescent bulb as my tester). Then next, if I affix a ground wire pigtail to the back of the steel box and to the new 3-prong receptacle ground screw, will this serve as a proper and safe grounded 3-prong receptacle?
