Note that the wattage you are going to use should not exceed the wattage of the original 12 volt lamp. You will need to replace the lamp socket, also, with a socket used for 120 volt lamps.
Still, you will void the Underwriters Laboratories or other safety rating of the fixtures and if you shoul have a fire, the insurance might not cover. For this and other reasons, they do not make conversion kits (except for fixtures that are really dual voltage); you would have to jury rig the new socket and other applicable parts.
