My toilet is american standard cadet 3 with 3" flapper. It came as low water use but my main sewer drain (4" cast iron, house built 1920's, don't know if original or replaced) got blocked and my main suspect is the low water incapable of flushing through the drain.
I did 2 things.
1. The flapper is adjustable. Check the videos. The flapper bowl is adjustable from 1 to 10. Factory setting is 1. I also bought korky replacement and it was set to 0. Resetting helped.
2. I also raised the height of the tube for toilet bowl water filler. I used a piece of 1.25" pvc thin wall tube and it slipped on snugly. No need to make it water tight. The fit may depend on the kind and brand of thinwall tube, so you may have to buy several kinds and see which fits. The tube I used is left over from a tail I used for bath. Not sure why I held on to this useless cutoff but somehow it was as if made for just this purpose.:smile: The addition can't be higher than the fill valve setting but adjustment is easy. I also set the fill valve float to max water. The fill valve has a nozzle where bowl filler tube is attached. Remove the tube and you may see a green nipple. The nipple is a restricter that is removed by pulling. Now, higher bowl water
The toilet functions as before but with 2 gallons now.
This created a new problem which is the trip lever which is plastic and making small creaking sound when pressed. I did a short amazon search but after market levers all have some weaknesses. I am looking for lever that is longer and will give more leverage. I would appreciate a headsup on a brand? American standard website has them also but above the ordinary is $30 and up.
This post is here and not plumbing by intent.
I did 2 things.
