1 - 12 of 12 Posts
Hi,
I am trying to convert this single double toggle switch to two separate switches. When I try it, they don’t work. How can I do this correctly? Do I need to add an additional wire?
Photos of the double toggle switch wired correctly and pictures of my new 1/2 paddle switches from Legrand.
Gas Engineering Electrical wiring Wood Machine
Rectangle Wood Flooring Font Brick
Wood Floor Flooring Gas Hardwood
Circuit component Electrical wiring Engineering Gas Electronic engineering
Super Moderator
Wire 3 is the power to the switches. You will need add 2 pigtails off of this to power the two switches. The other wires on the switch are the switched hot out to the lights.
The wires should have a clockwise loop around the screws.
Thank you!! Now I’m struggling with the other side.
Super Moderator
Wire 1 and 2 will each go to one of the new switches.
Electrical, remodeling
Are you trying to change to two seperate swiches in a two gang box or are you just trying to get a better more up to date looking switch?
This is basically the same switch just looks a bit nicer.
If you want two totally seperate switches in a two gang box, you will need to change the box.
Discussion Starter · #8 ·
I took an after picture! I was able to get 4 single (1/2 paddle switches,
Part number ASPD1531W4) into a 2 gang box. Wires are a little tight but it looks great!
Looks good.
Did you make the top switch for the lights in that room?
Taught years ago that when ganging switches, the first switch, closest to the entry way, should be the switch that controls the lights of the room you are entering.
Anyone else practice this unwritten rule?
1 - 12 of 12 Posts
