On the trailer I'm converting, I have two l5-30 inlet plugs that both feed into the panel shown on the bottom left and right.
Can I replace those two with one l14-30, and if so, how do I wire it? I've got a ground, neutral and hot coming from each of the l5-30 inlets now. Do I double up the ground and neutral from both of those, then use the hot from each in the X and Y like this?
Here are where the two l5-30 plugs are now.
Which is on the outside wall under this box.
And which feed into the bottom left and right here. (The center is coming from the old 20k generator and I'm wanting to put a 50 amp inlet there. Different thread coming.)
