gtothek said:
My house is 15 years old, 3 BR about 2K SF. My upstairs is always too hot in the summer and too cold in the winter. We had an attic fan installed last summer which seems to help a little. It just seems like the air flow never makes it upstairs. So what could be a solution to my problem? How expense would it be to make the house dual zone? Does that mean having 2 A/C units installed and 2 furnaces? Is there also a solution to add dampers to the ducts to direct airflow upstairs? I'm looking for some suggestions. If more info is needed, please let me know. thanks!
I had the same issues. research on the web started with a review of the static pressure within my system. a cheap used manometer from ebay and I found my static pressures within the ducts to be very high. a bunch more research and a cheap anemometer from ebay confirmed that I had poor air flow from the supply and poor return volume also. so what caused all of this? Flex duct caused the high static pressure and poor air flow. additionally, the return was to small for the oversized unit I have.
the solution was to remove the flex. I was lucky and the flex was only used as feed/trunk to all steel ducts in the walls. I also found that the registers were very restrictive, so they too were changed. additionally, I sealed as much of the ducts as I could reach. I think the biggest and best sealing work was a the register, supply duct and wall junction. The gaps there were huge and allowed air to enter the walls, not the room. I also doubled the return by adding a second return of the same size. The air flow to all rooms was vastly increase, something on the order of 2 times. the throw of the air and the comfort in the rooms is now great and I only have about a 1 degree difference from top to bottom. I also rebuilt the returns and made sure they could hold a 4 inch media type filter. the air flow through them is great and the dust in the house is way down and I dont have to change them but twice a year. we did as a result of all of this, find that the bedrooms were stacking up air flow with the doors closed. so I added transfer ducts from the bedrooms to the hallway. bottom line is that I did all the work myself, the cost was minimal, the comfort in the house is a 100 percent better and we realized a 25 percent electric bill reduction. I would be happy to provide pictures or answer any questions you have. btw, I did look into dampeners, zones and even a second ac unit. all of them had high costs and were not efficient for my situation.
