What is involved in converting a single zone HVAC to a dual zone system using one compressor? Given all my existing parts will remain and no new condenser or evaporators will be added, I assume it will require a baffle/damper to direct the air to up/down/both areas depending on which thermostat get triggered. What parts best suit this type conversion? Is there an intermediate circuit board which would be required?
HVAC:
Vendor: Lennox
CONDENSER: 10AC42-3P
EVAPORATOR/HEAT: 80MGF3/4-100A-1
Approx: ~15 yrs
HOUSE:
- Built in 1995
- 2200sf with existing thermostat on lower level.
- Evaporator and heater (gas) are in the attic.
- All vent lines are very accessible in the attic.
Regards,
-Inet
Administrator
Zone panel.
Motorized Dampers.
Bypass damper.
Thermostat/stats.
Hvac Pro
That furnace is prone to cycling on the limit control (lower temp type) so I would not want to throttle the airflow with dampers etc or it may be a problem. A newer furnace Lennox G71 with a variable speed ECM motor or G60UHV will handle that situation better. I have worked on hundreds of 80MGF/G24s.
