Was looking for a device(s) that would allow me replace two independent, existing hard-wired light switches (example, one porch light switch and one outside garage light switch), and allow them to work as a single group in a 3-way switch configuration wirelessly. Is there such a device? Here is an illustration I was looking to accomplish. Was looking to make these two lights work in a 3-way switch configuration without running new wires between the two switch locations:
I didn't want to go the route where you need to plug in a "hub" or be able to only activate the 3-way switching with some mobile app. Basically, wanted to have the two switches act as a 3-way with only replacing/upgrading the actual two switches as if they were wired in a standard 3-way switch configuration (minus the runner/traveler wires).
