Hi, we're nearing the end of a kitchen remodel, and the tile contractor didn't make sure the floor was level. It dips from left to right under the refrigerator (the cabinet box, itself, is level and plumb). This causes the fridge to sit crooked in the 36" cabinet box, so much that it can barely be pushed in. There are no leveling legs on the rear of the fridge, only the front. Raising the right front of the fridge throws the doors out of alignment, and the fridge is still crooked. If the right front were raised further, the door alignment would be worse. The right rear of the fridge also needs to be raised, so that the whole fridge is truly level. Or the floor needs to be leveled. The problem is that cabinetry has already been installed on top of it.
The contractor is currently discussing with his tile guy what to do. He initially proposed shims, but if we ever have to pull out the fridge for repair, we'll never be able to get those shims in place again. I asked if there's a way to modify the porcelain tiles under the fridge, possibly by replacing and raising the tiles on the right side.
I'm attaching photos of the fridge in the cabinet, with the right front raised up. Even with that, on the left side, there's a 3/8" gap at the top and it's tight against the molding on the bottom; on the right side, it's tight against the top with a 3/8" gap at the bottom; and the right door is higher than the left (the leveling legs move the doors, and there is no separate door adjustment).
Thanks for any suggestions you may have about the best way to fix this.
