1 - 10 of 10 Posts
I'm looking to add some LED shallow can lights (Lithonia ultra thin wafer 6") to a finished ceiling. There is a single switch already in the room - and it controls the top socket of an outlet across the room. There are no other switches in the room - and nothing else controlled by the 1 switch
The switch has red - black - copper. with Red always hot and the black the switched hot.
I cut holes for the lights and see 2 cables that run to the outlet.
Romex 1 live and neutral (black and white) is attached to the always on plug and the neutral is bridged to the switched plug. Copper is grounded.
Romex 2 has the black tied in to the black screw of top plug. The white wire is attached to the black wire from Romex 1 and black screw of the always on plug. Copper is attached to the other ground. There is a junction box on this line that I'd ideally like to use to tie in the 6 LEDs. When I test the junction box with a multimeter -, I see: Black / White = 0, black copper = 0, white copper = 124.
Can I tie in the cans to this junction box - and have them switched? If yes, whats the recommended wiring. I initially did black to black, white ot white, copper to copper - but that didn't work. The cans did not light - and the top switched plug became always live..
If I cannot tie into Romex 2 - how where would you suggest I tie in ?
Everything ready to go - and this is the final step ! Thank you!!!!
· A "Handy Husband"
Where is the red you say is at the switch? Are there more wires or cables in the switch box?
The switch has 3 wires. The red is always hot - and appears to come from the basement into the switch. The switch - when active - makes the black wire live. There's alos a ground / copper. That's it for the switch.
· A "Handy Husband"
A cable with only a black and red conductor is unusual in the US, are you sure there is not a white wire in the back of the box?
· A "Handy Husband"
A 2 wire cable is 2 insulated conductors and a bare ground. Cables are specified by the number of current carrying conductors.
1 - 10 of 10 Posts
