1 - 8 of 8 Posts
Hi Guys I have a questions in regards to getting continuity on a circuit I have off at the breaker.
So I will explain what had me perform the test in the first place, I am currently remodeling my kitchen and the girlfriend was requesting a switch to control the light over the sink since the old one used a pull string. So I got everything wired up and I wanted to make sure that I didn't have any shorts in my wiring. I performed a check at the terminals where the light will connect and I had continuity. I thought it was my wiring but I traced the wire to the wall and to a box where it got fed power and connected the light and an outlet below, I cut the wires to perform another check and it was not from my wiring or the outlet but when I measured the wires coming in to feed the circuits and again had continuity. Attached is a drawing of the circuit I tested. I wanted to add though when the circuit has power everything works as it should. I think this circuit has been this way since I owned the house but I didn't notice till the kitchen renovation. I'm at a loss of why would the circuit work if there is a "short"??
Yeah, loads count as limited-resistance shorts. Say you have two 60W bulbs (because it's 1977): That's 120W.
Watt's Law (to get amperage)
P = EI
120W = 120V x I
1.0 = I
Ohm's Law (to get resistance from amperage)
E=IR
120V = 1.0 * R
R = 120 ohms
You generally should avoid tapping power at a switch. Switches often don't have always-hot and neutral, and often have weird stuff (3-ways).
1 - 8 of 8 Posts
