Nobody. Continuity can't be detected that way. Are you referring to contact voltage detectors?
CONTACT contiinuity testers?There's hundreds of companys that make them
Arghh...I feel like a rookie for asking this...but I appreciate the help..
Might want to share what you plan to use it for to narrow it down.
Too true... but with this probe you don't have to use a meter....just pull the fuses and put the probe to the fuse.Any continuity tester would work for fuses...you just have to remove them from the circuit first.
There is a contact point you hold with your thumb at the top Can't see it in photo.As I said earlier...you cannot check continuity from one point.
