ditto on the PL Premium
Excellent adhesion on wood and many other substances. Polyurethane like Gorrila glue. Stronger than the wood you are joining it to.
It expands a little as it cures. Normally I like this, because it fills the gap from less than perfect cuts. For example, if you are using it on corner miter joints on molding. But if you are using it where it will be visible, you have to remember to go back after 20 minutes and wipe off any excess that has oozed out (sometimes a little varsol helps).
Seems to work well on plastics also.
