1 - 8 of 8 Posts
Any suggestions for good connectors for a low voltage landscape lighting system? Started off with the Malibu style that mostly work by 'piercing' the cable. They seemed to fail after a few years. The last thing I've tried were these
'Nano-Junction' connectors from Volt Lighting: https://www.voltlighting.com/nano-j...ector-3-way-black-plastic/p/BDL-VAC-WC2-PBK-2
They do seem to have an excellent design.
Just don't know how long they might last.
Thanks for any thoughts or advice!
A "Handy Husband"
Looks like a Wago in a gel pack. Nice but expensive. I use gel filled wire nuts.
Sent from my RCT6213W22 using Tapatalk
Discussion Starter #4
Thanks rjniles and KHouse75!
I've used those gel filled nuts as well.
They seem to be holding.
Thanks for the pointer to those Wago's.
I've used their push-in connectors.
The ones with push down levers look even better.
Well, nobody suggested those 'piercing' style connectors.
I believe I've got all of mine replaced now.
Thanks again!
I've had Malibu low voltage lighting on my house since about 1981. I've always used the pierce type connectors but in the last few years have been plagued with failures. I decided to just remove them and solder the light fixture connections instead. Problem solved.
Discussion Starter #6
Hi, Dave Sal!
Well, I bet soldering will definitely work.
That's a great idea.
Do you tape the connections? Or heat shrink?
Hi, Dave Sal!
I'm using heat shrink tubing. So far, and it's been a few years since I started doing this, no more failures.
1 - 8 of 8 Posts
