1 - 9 of 9 Posts
We pick these?
My electrical official at the compliance office suggested that I can use the existing 10-3+ ground dryer homerun to satisfy requirement for (2) dedicated 20A GFCI circuits in my laundry area. He said I need to share the neutral. The info I've seen disagrees whether to use separate 120v 20A breakers in the box or to maintain a 240v 20A double-pole breaker. There is a junction box in the bathroom where I will obviously need to pigtail the neutral wire of the 10-3 to both the 12-2 wires. Can someone advise me how to do this in a residential situation? BTW, we are using NG for the dryer, the 10-3 has been unused for 15 years but is intact with a 30A double-pole breaker.
Thanks
Licensed Electrical Cont.
Under the 2008 NEC you must use a 2-pole breaker.
Although not always mandatory, in any case it is a good idea. :thumbsup:
Banned
Yes, you would need to replace the 30a double pole with a 20a double pole
I'm aware of the requirement for a single dedicated laundry circuit
Why is he asking for a 2nd circuit?
You mention a laundry area then talk about a bathroom?
Are you running one circuit to the laundry area & one to the bathroom?
One 12-2 goes to one area, black to black, white to white, ground to ground
2nd 12-2 to other area, black to RED, white to white, ground to ground
Bathroom must be GFCI protected
Laundry outlet if within 6' of a sink must be GFCI
We pick these?
thanks for speedy responses
I've divided the old "large" laundry room and "miniscule" powder room into a full bath for the new master suite and a combination powder room/ laundry room (laundry equipment in 3x5 closet). I have the GFCI's covered already for the bathroom requirement and was aware of the requirement for the washing machine. The official said I also need a dedicated GFCI for the dryer. I am operating under a homeowner self-permit. In short, I don't know "all" about electrical codes, etc... I'm assuming he's told me what he wants to see, as far as a dedicated GFCI for both washer and dryer. There is (1) 20A 120V single pole home-run circuit to supply (2) GFCI in the back to back bathrooms, and the 10-3 will supply the washer/dryer split into (2) GFCI's, at least that's what my E.I. suggested and I'm taking his advice as something that will get me a green-tag.
Banned
A laundry area does require a dedicated circuit & that circuit can't leave the laundry area.
If the laundry area is now in a 3x5 closet then the circuit can't leave that closet
Dryer you stated is gas, so you need a 120v connection
The dedicated circuit can feed both the washer & dryer
There isn't anything that indicates a need for 2 circuits
Unless it is a local requirement
OR
The washer takes up a lot of power
But in the end you need to do what makes the Inspector happy
We pick these?
Makes inspector happy, I'm happy
It may be local code in Indianapolis to have (2) dedicated circuits for laundry, or it may be my own special requirement, I don't really know. I didn't think it made sense to require a dedicated circuit for the dryer, but it's not a big deal with the wiring already there. I have plenty of home-runs: (1) for smokes, (3) separate GFCI's in the bathrooms and laundry, and still have (3) circuits for the bedroom, study, and sitting room.
Thanks for the assistance, folks.
Before I forget. One of the 20A circuits is a double-pole with 12-2 wire. Can I move the white wire to the neutral bus and leave the double breaker in place, rather than purchase a single pole breaker and blank? The other 4 circuits are all 20A single pole breakers with 12-2.
Super Moderator
Yes. We may get called a hack for doing it that way, but it can be done.
1 - 9 of 9 Posts
