Nordyne M1M Series Propane Burner w/Intergrated Furnace Control Board, furnace 7-years old. Nothing known about its history.
Upon arrival, initially check out furnace visually, and while doing so owner starts adjusting mechanical tstat, producing a violent stuttering of the gas valve, but only momentarily... maybe a long 1-second or so. Not long after, I find the protective cardboard insert still in place in the tstat. I could take a stab at it, but not sure of its exact purpose. The protective part of the insert surrounds the vertically positioned center-post that moves between the two contact points on either side of the center-post as you adjust room temp setting.
After a new board installed, all is well again. Only much later after upgrading the tstat to digital (also figuring the stuttering was due to the cardboard insert still being in place), do I find out that this occasional stuttering had been going on during furnace operation for at least a couple months, but not sure exactly how often. Daughter was the only one home most of the time and was the one who told me that the furnace "was doing that a lot."
Could the "stuttering" have been what killed the board? Yes, or Poo-poo?
