During new home construction, had builder add a 30 amp circuit for future RV power. New construction single gang box with GFCI outlet (electrician had to install a receptacle for inspection) and weatherproof cover.
I want to eliminate the GFCI outlet and run conduit from the box to RV pad.
What is the proper way to connect conduit (preferably pvc) to the box? Research only results in surface mount boxes but no in wall boxes.
Any help would be greatly appreciated! Thanks!
