I'm getting ready to install a transfer switch next to my main panel, but in order to install it I need to move some on-wall conduit out of the way.
Here's what the space looks like now, with the prior conduit positions shown:
And here's what I want it to look like: The conduit will transition from on-wall to in-wall near the ceiling, go down the wall behind the transfer switch, then turn left in the existing junction box and head to the main panel.
A few details:
1) The conduit holds two hot and one neutral #8 THHN for a heater in the garage.
2) The to-be-installed transfer switch is about 3.5" deep, leaving about 3" of clearance behind it before I hit the other side of the exterior wall
3) The coax cables you see will be routed into the space between the studs to the right, so they will be out of the way
Here are my two questions:
1) Can I, while being 2017 NEC code-compliant) route the conduit behind the transfer switch?
2) The image below is how the prior owner handled the on-wall to in-wall conduit transition -- Three of these metal boxes screwed together, with a face plate on the front. Is this is best way to do it? Other (better) suggestions?
A few details:
