Usually 50 feet with the standard size lines that come out of the unit.
You can go longer but then you need to check the manufacturers specs and go with one size larger suction line. That gets pretty expensive.
I usually try keep them under 50 feet. Get a copy of the install manual for the unit and it will tell you what size and how long then can be.
