Hi everyone,
I have a split entry home and I have a master bath on the back of my house. It is a new home that is almost two years old. The bathroom has a two foot stickout the whole width of the bathroom which is 12 feet, so hence there is a stick out in the attic as well. I hope that is clear enough.
I had moisture in the two outside wall/ceiling corners in the bathroom and down the wall a little bit, I called my contractor and he came and looked at it and took the soffit down and looked up in there and there was very little blown in insulation in the attic in that two foot stick out part of the ceiling so there was condensation between the drywall and vapor barrier, he told me to turn the heat up in the bathroom and see if the condensation increased and then we would know for sure what was causing the moisture problem and indeed the condensation increased quite a bit. We did investigate for leaks in the roof and leaks in the HRV lines and in the plumbing vent in the attic and found no problems, it was just isolated to both corners in the ceiling where very little to no inulation was... so I agree that it was a condensation problem due to heat loss into the attic with the heat in the bathroom and taking showers.
I didn't have this problem last winter because that washroom wasn't in use and the heat was off and the door closed and I finished the bathroom this summer and now we are using it and noticed this problem now.
My contractor reinsulated that space but I still have moisture in that area when we turn the heat up and shower in there... with the new insulation in place and no more heat loss there, will this moisture just evaporate and dry up eventually? Or will it be like it for the rest of the winter and then dry up next summer? I know the moisture is trapped between the ceiling drywall and vapor barrier but will it just dry up through evaporation eventually? I hope the condensation is stopped now that it is sufficiently insulated and it just needs to dry.
I live in a northern climate on the east coast of canada.
Sorry for the long winded post but I just wanted to try to explain it clearly.
Dave
Dave
