A condensate pump was installed with my new high efficiency furnace so I also tossed in output streams from the humidifier overflow pipe in winter and dehumidifier and A/C in summer.
What I'm finding is the check valve needs replacing far too frequently.
Explaining this to a serviceman, he said the extra streams add much more complex sediments into the pump, which cause early failure of the check valve.
Now I'm on a hunt to identify a filter that could be used to filter out the sediments and extend my check valve life. Any ideas?
Thanks,
Thanks,
