I'm the 2nd owner of a split foyer home that has a finished basement with the utilities in the basement. There is no drain in the basement and the builder installed a pump for the condensate line and have it coming out directly next to the AC unit outside. Recently we noticed water getting in the basement. I ripped my bathroom apart and found a crack in the foundation wall that is letting the condensate discharge run back in the house. My original plan was to tie the pump to the main sewer line which is less than 2 ft. from it in the same closet, but after reading some posts on here I'm not sure if thats a good idea? My only other option is crossing the hallway to tie it into the washing machine drain, but that would require going thru joists.
Any idea's?
Any idea's?
