Hi,
I've recently started setting up my own Home Inspection business here in Maryland (where I am licensed). I've come across a situation with my own system above my second floor in my two story home. Two summers ago the drain from the unit got backed up and the drain pan below over-flowed and caused considerable damage to the ceiling in the Master Bathroom below. The service tech said that the galvanized drain pan under the unit should have been piped up with a secondary drain out to the soffit on the house to prevent the pan from over-flowing. I put this pipe in and tested it. That part worked great, however, I believe the galvanized pan has rusted through somewhere because the little bit of water left in the pan that did not drain out of the secondary drain pipe (i.e. because it is below the level of where the pipe comes into the side of the pan) is leaking through the bottom somewhere. Has anyone on this message user group experienced anything like this? What do I need to do to replace this galvanized pan with a plastic one and where can I get the plastic pans? I would imagine that I could temporarily suspend the unit from the rafters and raise up off the 2 x 4 's that the unit is currently setting on that are inside the galvanized pan long enough to replace the pan. I'm guessing I can raise it about an .125 to .250 inches in order to do this without disturbing much anything. Unless someone can give me a better solution or point me to a website for direction that will save me money in these tough economic times.
Please advise,
Steve
Please advise,
Steve
