Hi,
I have cast a small concrete pad for an outdoor kitchen area, its about 5' by 12'. I'm grinding it to expose the aggregate, and then plan to polish and seal it.
I'm looking for recommendations for penetrating sealers that will work with a polished (or semi-polished, I can stop at a certain grit if needed) surface, will last in the sun, and don't change the appearance of the surface much (i.e. not shiny). I'd also need to be able to add some level of non-slip to it.
So, summary, I'm looking for a penetrating sealer for:
Area: 5' x 12'
Concrete Finish: Ground and semi-polished or polished
Environment: outdoor, in the sun
Use: pad under outdoor kitchen
Desired final finish: as close to the bare concrete as possible (as matte as possible, not wet look), sealed, and non-slip
Area: 5' x 12'
