1 - 11 of 11 Posts
I would like to expand current basement windows into egress windows as a project later this Spring. Thing is, that concrete saw looks scary. I’ve never used one. Huge blade.
Everything on YouTube regarding this saw is only 5 min and no mention of safety or how to use.
· Master General ReEngineer
Ayuh,...... Are you comfortable with a standard chainsaw, say with an 18" or 20" bar on it, in yer hands,..??
If so, it's much like runnin' a demo-saw, only more dangerous(the chainsaw),.....
Biggest difference is a demo-saw has more of a gyroscopic effect than a chainsaw,.....
It takes more effort to go from up-right to sideways, but once turned, the effect subsides,.....
For cuttin' a hole in a wall, ya need the 14" blade to reach atleast 1/2 way through, on each side,......
You can use a smaller saw to get started, first two inches. Then the monster saw has a path to follow and will seem much less intimidating.
Bud
· Banned
Ayuh,...... Another option is a Concrete Chainsaw,......
You might find one available locally at yer favorite rental shops,.....
The chain will be more expensive than a blade on a demo saw...keep that in mind.
Issue with a demo saw is that you can cut the corners. You have to finish that with an angle grinder and a diamond blade.
14" blade will JUST cut 5" deep if you're lucky & change the blade collar to a smaller diameter,,, make the 1st cut w/4" dia blade on hand grinder,,, no matter what, you'll still have to address ends UNLESS you overcut,,, easiest way to do this is drill a hole thru 1st then measure & layout based on its location,,, cutting wet will be messy but also very little dust
· Concrete & Masonry
Block basement or poured? A block basement could be done with a 7" circular saw, if you had to, and you could lay it out without hitting any webs. The other benefit of cutting a block wall is that you don't have to cut the horizontal either.
Making the vertical cuts is easy. What is difficult is making a straight and level horizontal cut with a hand held circular concrete saw. I would look for a saw that is mounted on an assembly, much as is used for core drilling in concrete. This is one of those projects where it is better to hire a professional who has their own tools and has years of experience and has their own medical and liability insurance.
This is not a good time to risk getting seriously injured and having to go to a hospital and possibly pick up Covid-19 and other infectious diseases like a mrsa bacteria.
1 - 11 of 11 Posts
