I'm in the process of designing and installing a new deck. The deck shall be approximately 40ftx15ft with wood framing and composite/vinyl decking. To minimize the amount of wood columns, I plan to use 3 steel columns with an 8 inch I beam (girder/header). The 12 inch joists will span approximatley 15 feet from the ledger to the 8 inch steel girder supported by the 3 4inch or 6inch columns. The steel is more than enough to support the deck load, but not sure as to what the footings should be builit to? My town code requires footings to be lower than frost line (42 inches). Not sure what size footings and or reinforcement I would need?? Any advice would be valuable...
