1 - 10 of 10 Posts
i am dealing with the colder spring weather, and i am very antsy to get this done. just how cold is it still ok to set posts ? idk what the ground temp is. its 30 outside now, but supposed to get in the 50+ today.
i cannot get the spec sheet for the bags i am using.
All concrete is affected by air temperatures, the concrete in your post holes will be okay below the soil level, but if any is exposed it will freeze at 30 degrees if it's not protected.
http://www.cement.org/for-concrete-...concrete-construction/cold-weather-concreting
· Master General ReEngineer
Ayuh,...... How deep ya stuffin' the posts into the ground,..??
What's yer soils like,..??
Discussion Starter · #8 ·
ok, i got 3 more posts in. no issues, sept for 1 hole many and 1 large roots.
the holes are about 1' soil, then clay, varies on each hole. most holes i go 3'. critical posts i go more. a couple i went less = rock or somethin' in the hole = 2'ish. i then throw in some road mix (its what i have) . i used 8'ers in these holes, as i had em and well, didn't need longer. i ain't worried about em.
anyway, temps were not a problem, as it got to 70 = great !
1 - 10 of 10 Posts
