1 - 10 of 10 Posts
The title may say it all as this is new territory to me.
Live in Florida, 2016 home, concrete block - standard Florida issue and build.
West exterior wall has concrete pads where AC and pool equipment are anchored. Sun stresses everything here, and 4 year old pool equipment is taking a beating. To slow the deterioration, I was going to construct a simple angled cover with fiberglass panels. When I added costs, time and the important fact that it would probably not withstand our wind, I looked elsewhere.
Found a 8" X 7 " awning, retractable, mounts with 2 brackets, 4 concrete anchor bolts.
The awning will be 6' from the ground so I have no header to use to mount.
The awning is retractable and I will using it as 8' W X 6' out.
Question is not simple, because stucco covers cinder block.
First ignorant guess, if I could find 2 seams or cinder block "studs" the correct distance apart, I could mount using the supplied sleeve anchors (or replacing with epoxy anchors). The brackets are simple 2 hole that stick out about an inch from their mounting, the awning slides in and is held by 2 vertical bolts.
Second ignorant guess, mount a 2" X 6" X 8' board with 8 or 10 (12??) epoxy anchors drilling into cinder block as necessary and mount the brackets/awning to the board. The awning is removable and would be removed in case of a hurricane, but wind shears of 40-50 mph happen quite often and unexpectedly.
I would like to keep my wall intact and mount this properly, so any help is greatly appreciated. Added 2 pictures for a little clarity.
FYI, I know one solution would be to fill 2 cinder blocks from outside with cement, then drill and mount anchors - it seems inelegant, and I'm still not sure of the stress on the block or if I have the skill to even accomplish that.
Block her 8”x 16” long Which means if you drill a hole and find the cavity will be another cavity every 16 inches and you can do you toggle bolts if you drill a hole and find a stud or the web of the block you’ll find another one every 16 inchesAnd you could use tap cons you can also drill more holes in your bracket to have a total of four or five across
wouldn't web's strength be stronger for pullout AND shear ?
Sorry. web's strength?
I do not understand the referral, but I certainly am concerned about pullout and shear! I'm pretty confident toggles would be insufficient. But is there another way to spread weight/stress and maintain integrity?
When you say the web of the block, I'm sorry, but I do not understand the reference. My issue is FINDING those seams/web under stucco and hopefully avoiding the cavities. Using them would let me safely use sleeve anchors. Any thoughts? Hit and miss by drill seems a little old fashioned.
Discussion Starter · #8 ·
Just saw on my blueprints I have a "grouted cell block" with rebar every 7' in the exterior walls. Would this imply or refer to a "filled" vertical column of cells? And would this be the place to start measuring from to find the web or seams of the block?
locating the exact spot's going to be tough BUT, if the fill'd column of grouted cells falls right for your attachment, that's the place - lags & lead drop-in's
1 - 10 of 10 Posts
