"using bits from Home Depot". Home Depot sells a number of brands of so-called "masonry bits". A good, known brand, such as the Bosch mentioned may be the answer to your problem. Now--is the DeWalt 1/2" drill a "hammer drill"? I'm not familiar with the Mastercraft, so I can't judge it. You will need (can we say "must have") a good hammerdrill to do this job. I have drilled into a lot of old concrete and I don't know whether it was because of it's age or mix back then, but they are harder than today's concrete. 1) A good, brand name, carbide tipped masonry bit, and 2) a good, preferably brand name, hammer drill should drill into this concrete. Granted that a stone or re-bar will make the job harder. Someone with experience can tell if they are hitting a stone or a metal re-bar, but both can be drilled through with the proper tools and procedure.
