help please. my outdoor ac unit keeps burning up wires at the compressor connections. i believe that arcing is burning up the spade type connections. the problem is that it has burned up the lug that the terminal slides onto. there is a special wire used to repair this that has some type of screw clamp on the end to attach to the compressor lug. does anyone know what these repair wires are called or where i can find one? thanks for any help. kevin in tx.
wires
thanks for the reply yoy. it sounds like a good solution if i can get to the terminal to drill it. the compressor is at the bottom of the unit and is surrounded by the ac coils. thanks again. kevin
