The PVC doesn't fade. There reliaboard composite will slightlythomasjmarino said:TimberTech is a good product.
I use it for the decking on my projects.
Only thing, it does fade slightly from its original color.
How much TimberTech have you installed?The PVC doesn't fade. There reliaboard composite will slightly
This is true!! :thumbsup:The fluted underside is to save on material. The thickness of the board is less as well I believe it is .94 of an inch whereas the PVC is a true inch and it's slightly wider. To answer you question probably 4000-5000 sq ft of reliaboard.
