I've seen that done with old homes (non-grounded wiring) and partial rewiring work done. Maybe a new room addition with new wire, then they later replace the main panel and wires going to that. Use the jumper to pass inspection or sell a house before the main panel is replaced.I looked at the panel and the ground wire is ground at the panel. Any idea why they would do this?
They can share the same bar in a service panel.Grounded to a separate bus bar? Meaning all the white neutrals are on one bar and the bare ground wire on another?
If not, I would get this fixed first. The reason for this is to eliminate a parallel path for the neutral current.
I can't really see it but that would explain using the ground to make up the possible missing neutral I mentioned post #10.Hard to tell, my eyes aren't what they use to be, but it looks like the brass tab between the screws is missing.
As long as they are bonded at the first point disconnect.Didn't know that.... thanks.
Is it ok to split them in a service panel?
I did this when I put in a larger panel a few years ago.
