1 - 10 of 10 Posts
Hi, sorry you didn't get a response sooner. We hvac guys hang out in a different area of this site.
To answer your question; there are not any manuals that are available to the general public.
What kind of problem are you having?
Discussion Starter #5 (Edited)
Comfortmaker Furnace
You responded to my request for a manual so that I could do some troublshooting on my own. I understand that the manual is not available to the general public.
I cannot get my furnace to turn on. So far, I have tried shutting everything down from the circuit breaker and resetting it but that did not have any effect. When I attempt to turn on the eight year old furnace it does nothing. Not a sound.
Can you help to troubleshoot this problem
I'm Your Huckleberry
Start with the obvious, make sure you have high voltage to the furnace, check the breaker. Than the fuse on control board, then transformer...
As for basics, don't forget to verify or check/change the thermostat batteries, if any.
There's got to be bolts that you loose to take tension off. Or you can turn by hand while prying the belt off. Watch your fingers.!
Quite the leap from "basics" to replace the blower belt. Maybe it's broke so there will be no tension to remove.
1 - 10 of 10 Posts
