Hi all,
We live in Oregon, which has horribly unhealthy air quality from smoke due to devastating forest fires nearby. I would like to filter our indoor air some without running heat. How can I turn off or unplug the heating elements to run air through the filter without heating up our house?
We have an electric furnace Coleman Evcon Model number EB12A.
I have enough handyman experience to change parts on our furnace but not enough to diagnose electrical problems beyond finding shorted wires.
Than you!
Donald
Does your unit have a blower on switch?
Most hvac equipment isn’t designed to be used as indoor air cleaning equipment, the filter is only there to protect the equipment.
Discussion Starter #3
Thank you for the response! After reviewing the wiring diagram, it appears that the switch in there is just for the fan. I appreciate the warning, too, about its designed usage. The air quality index, however, has been between 300-500, so even running some of our air through the filter will be a worthy breath of fresh air. Thanks again!
