Hey i have a code compliance question. I am not an electrician i am an auto mechanic/shop owner and i just had an "addition" built. Its a steel building that sits 2 feet away from my existing building. My utility company is upgrading my meter to a 400amp from a 200. I have a 200amp panel in my "old" shop and a 200 panel in the new shop. We will be using a 200amp service disconnect panel to feed the new panel in the new building. The disconnect panel will be next to my old 200 amp panel. My question is this. My electrician wantS to run 2.0" emt from disconnect panel secured to the ceiling out the wall to 2 feet outside and into the new building to the new panel. We are using 4/0 4/0 4/0 2/0 aluminum SER wire. Can i just run emt tubes to the attic and have the ser cable exposed in the attic on top of the trusses and then it go down with emt tubing into the new building or is this a code violation? The ceiling mounted 2" tubes looks bad in my opinion. Thanks in advance for any suggestions.
Im in virginia and my county considered this a storage or shed. No requirements for permit other than code compliance on whatever we do.
