Hello,
I recently purchased a vintage condo and I'm starting to find some interesting construction throughout. Please see the photos I have attached.
In the photo titled "living room" you'll see a coax cable which I have split 3 ways with the two white wires going to TV cable boxes and and one black cable going back into the wall. On the other side of this wall is my office, and I have that cable going to my modem. In the "living room" picture I am holding another coax cable which I have no idea what it does. I've tried to hook it up to a cable box but it gets no signal.
If you look at the "office" photo you can see the black coax cable which I referenced earlier, this is going to my modem. I am holding a CAT 5 cable which I do not use. Perhaps the building is wired for DSL internet?
I want to clean up this wiring as I have ugly holes in the wall and wires going every which way. I'm considering doing the following.
1) Putting a cable 2 way cable splitter in the wall, and putting a coax wall plate in the living room and then splitting that again on the outside of the wall to go to the 2 TV cable boxes. In the office, I would put a wall plate with Coax and a CAT 5 connection.
OR
1) Putting a cable 3 way cable splitter in the wall, and putting a dual coax wall plate in the living room and then I would hook up each TV cable box up to this wall plate. In the office I would do the same setup as above, putting a wall plate with Coax and a CAT 5 connection.
Do either of these setups seem advisable? Any issue with putting a splitter in the wall? Do I have to worry about signal loss with splitting the cable? There is also that mystery coax in the living room. If I just put this in the wall connected to nothing would that be safe?
Thank you.
OR
Thank you.
