1 - 1 of 1 Posts
Hello guys!
I want to make a rotary spray painting mechanism based on an airbrush concept, for internal coating in pipes. I want to use CO2 cartridges or propellant cans as air source. As option also I consider to use a CO2 tank and a solenoid valve + regulator.
I want o use Scotchkote Epoxy Coating EP2306SF, in the specifications of this paint, tip pressure is around 2500-3000 psi, and material temperature of 40–50°C is required
Does those characteristics have to be taken 100% in consideration in order to get specified wall thickness?
Can somebody advice me maybe another epoxy coating, or to clarify if under low pressure I can still achieve 100 microns of WT?
Thanks in advance for any comment to this post!
Will be grateful for any comment to this post!
But I don't know if the pressure of those sources will be enough to complete the painting
1 - 1 of 1 Posts
